Electric Fans
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
So you got you some from an 02 Montana? So you're using them as aux fans instead of the main fans?
no they are gonna be my main fans , that fan you see is the factory aux fan installed from the factory ,the Montana fans will be used instead of the clutch fan.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
Should be the same as Venture, Montana, etc.
hey do u hv a picture from the other side I am using your set up as a base or if not I will do the exact same thing you did , just need to see the other side to see how u did that bracket.
THANKS IN ADVANCE
THANKS IN ADVANCE
I'll look for a pic, if not I'll get one if it quits raining later.
77 K20
Montana
K20 5" lift
HT383 fuel injected
There was an aux fan from the factory? I don't remember seeing one on my old 86 K5 or my dad's 87 K5.
Was it an option?
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
Was it an option?
it only came on the bbc as far as I know mines is an 88 square body r3500
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
BLAZER/JIMMY (full size) 87-91 Fan Assembly
CHEVROLET 10 PICKUP 85-87 Fan Assembly
CHEVROLET 1500 PICKUP 88-96 Fan Assembly
CHEVROLET 20 PICKUP 85-88 Fan Assembly
CHEVROLET 2500 PICKUP 88-96 Fan Assembly
CHEVROLET 30 PICKUP 85-88 Fan Assembly
CHEVROLET 3500 PICKUP 88-96 Fan Assembly
GMC 1500 PICKUP 85-96 Fan Assembly
GMC 2500 PICKUP 85-96 Fan Assembly
GMC 3500 PICKUP 85-96 Fan Assembly
SUBURBAN 10 85-88 Fan Assembly
SUBURBAN 1500 85-96 Fan Assembly
SUBURBAN 20 85-88 Fan Assembly
SUBURBAN 2500 85-96 Fan Assembly
:hands:
Was it an option?
It was an option on the 3/4 and 1 tons as a Heavy Duty Cooling Package If Understand Correctly. As far as I know, it only comes with 454 too.
Beatdown Z
Newark, DE
That's the results I had been anticipating when I ran a cooler stat. Didn't work that way for me.
It worked for me and for the cost of the thermostat, it's worth a try for those with engines that run a little too warm.
I think the design of the thermostat is important too. I just switched from a standard flow MotoRad 180* t-stat (part # 200180) to a High flow MotoRad 160* (part # 2000160) with a 3/16" bypass hole drilled in it. This is in my Camaro which has a built 400 small block. Temps sitting at idle with my ****** electric fan on dropped 15-20 degrees.
Rockauto has the MotoRad stainless steel High Flow thermostats for under 4 bucks. Part numbers: 2000160, 2000180, 2000195
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
the thing is u cant use it will fuel injection it will take to long to get into close loop if it does at all , this is what I hv read . idk from experience, I wanted to do this in my 1987 454 tbi
I've ran a 180 stat in my TBI Burb for 7 years and it always goes into closed loop in a short amount of time. I have had a heated O2 for several years (mostly because the long tube headers) but it was fine before that too.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
what about 160 and a heated O2
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
You guys with electric fans have you had to upgrade your alt to make up the lost power
Snips71
