Electric Choke Power Source??
97350
Canada
Duane
C1500
I just installed a 406 and a Demon carb in my 83 Chevy 1/2 ton.I cut the connector that went to the factory electric choke and connected it to my + on my Demon carb. I'm not getting 12v from the connection and my choke light is on.Isn't this wire supposed to have power all the time?Also how do I get the choke light to turn off?
The truck was originally a 305 ESC but when I got it all of the original drive train had been removed.
Any help will be appreciated.
That choke light is actually a low oil pressure indication. I'm not saying you have low oil pressure but the power over to the choke must first pass through the oil pressure switch. The oil pressure "switch" is the one with two connections - not the one that has a single connection and looks like a bell. That is the pressure "sender" for your gauge.
When the engine is started and oil pressure is developed (about 10 psi) the contacts in the switch close and power is supplied to the choke heater via the light blue wire.
Why there is no power on the light blue - IDK. Check your fuse block, there should be a 20 amp fuse for the choke. Check for 12VDC coming into the switch on the pink/white wire. The dark blue goes back to the dash and powers the choke lamp.
If power is available at the pink/white into the switch, pull the connector off and check for continuity through the switch while the engine is running.
If there is no continuity across the switch, and you are sure that you have at least 10 psi oil pressure - change the switch.
83kid
Massachusettes
Nevermind, Chengy has everything about it in his post!
97350
Canada
Duane
C1500
When I installed the engine I never connected a low oil pressure switch.Would this tee off the connection for the oil sending unit? Also am I correct to assume that the wires coming/going from this switch are pink/white?I'll definitely check it out.I'll also check the fuse.
The truck is/was completely original until the engine was removed by the previous owners.The stock 305 threw a rod in 1989 and it sat until I got it about a year a go. 89k on it.
Thanks
No, the oil pressure sender only provides a variable resistance to ground for control of the oil pressure gauge on the dash. The choke heater is in series with the oil pressure switch, it is not connected at all to the oil pressure sender.
Read my first post carefully, the colors and functions of the leads connected to the oil pressure switch are described in detail.
MadOgre
NA
NA
NA
NA
NA
So could a guy run 12 v ignition from the fuse block run it through the 2 tab oil pressure switch and over to the electric choke for an after market carb. I assume so as the OP has a demon carb ?
350runner
tx
Ceasar
That's what I do.
Yeah, that's exactly the way it works as designed by GM.
One thing to be aware of however, Rochester designed the heating coil (used to drive the choke open) to be grounded through the choke heater body. Only a hot lead is required to operate the heater.
On the other hand, the coil used on many after market carburetors has no path to ground within the choke heater body. That's why they often have two tabs. One is for the hot lead and the other provides a connection point for an external ground wire. That ground wire can go to any convenient spot on the engine.
97350
Canada
Duane
C1500
OK thanks again.I pulled the 20A fuse today at lunch and it was fine.I need to track down the wiring that went to the op switch and go from there.There are quite a few wires that aren't connected,leftover from the esc/knock sensor.I can run a new wire but I'd like to use as much factory stuff if I can.
The pink/white and the dark blue will come out of the harness loom and lead over to driver's side. They should emerge from the split in the loom somewhere around the distributor.
The light blue wire (the one that eventually connects to the choke heater) will be in the side of the loom that goes towards the passenger's side. That one should be easy to find. If you have to, just start splitting the loom open over near the carb - you'll find it. When you do, just trace it back to the other end - or pull it out and run a new one.
The pink/white can be fed from any IGN energized feed. You only want the circuit energized when the key is turned to RUN (the IGN bank on the fuse block is hot only when the key is in RUN).
Canada
Duane
C1500
I finally had some time to check it out and found the unused connector.I installed a jumper to turn the light off.Thanks for the advice.
Scott91370
Burleson, Tx
Scott
Sierra1500
I know this is an old thread but what wire, if any, plugs in to the left side of the 'bell' shaped thing right behind the distributor hole?
Woah your engine has quite the collection of gizmos and it looks like your gasket on intake might have a small leak. Could be my eyes failing me. Best thing I did was new intake and removal of all extra nonesense on top the motor. Still working on getting it perfect, but its better.
On my carb, I, in a pinch, sent power from another switched ignition off another circuit for my choke. I chose to use the power wire for the wipers. I justified it because Im not on the road and my wipers need serious overhall, (including new connector), so potentially compromising power on that line wasnt a huge deal. It runs straight across the motor, in the way sometimes. Ill eventually put a power point in my bay to power other accessories, that pull from a relay and battery so im not putting power on those circuits. I decided to ground my choke right on the bracket for the alternator. If its good enough for the battery, its good enough for my choke. Didnt even need to drill a hole, had a couple pre drilled openings.
That's oil pressure sender. Only used when equipped with a gauge package. There is just one terminal - that a TAN wire connects to:
78ALB
