ECM compatability between years (dead V1500 diagnosis)
rumblebox
Victoria, TX
Carlton
I'm working on a 91 v1500 suburban, and i need to try another ECM. Can i try one from like a 94 k1500?
Theres no power going to the fuel pump, and even with the [new] fuel pump hot-wired, it still only fires if i pour gas down the intake. The SES light would come on sporadically with the key on for a while, but now nothing. There is juice going to the orange wires on the ECM connectors. The fuel pump relay clicks when you turn on the key, and it has power to the orange wire, but no power comes out of any of the wires. It sat for about 5 years and ran when parked(poorly, but i already traced that to a leaky fuel line).
4WDKC
Southern Florida
Kacy
when you pour gas through the tb and the truck starts does it continue to run? If so probably has a really high idle and you can hear what sounds like a lot of air rushing through a small hole right?
rumblebox
Victoria, TX
Carlton
No
Sent from my SAMSUNG-SM-G870A using Tapatalk
yevgenievich
Viktor
sad
very sad
less sad
94 ecm would not work. 88-91 i believe will. You need to verify if injecyors are trying to open with noid light
88SQDRW
