dropped spindles
MikeB
North Texas
dropped spindles vs. cut springs for approx 2" drop
I was going to buy some McGaughy 2.5" dropped spindles, but read about quality and customer support problems on this and other truck websites. And then there's the issue of my 8" rally wheels hitting the tie rod ends.
So, is there one brand of dropped spindles that works well, even with 8" rally wheels?
If not, is using 2" drop springs (instead of dropped spindles) going to create any problems, other than requiring an alignment?
How about simply cutting a coil off a stock spring? A Moog spring costs less than half as much as a dropped spring. But will it be too stiff when cut?
I also plan to install hangers to get 2" drop in the back. Overall, I'm looking for just little drop with a slight forward rake.
My truck is an 82 C10 short bed with 1" thick rotors.
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
I have BellTech 3" spindles and 8" rally wheels. The control arms required some minor grinding to clear - just don't get greedy.
I also cut 1-3/4 coils off 1-ton springs.
Mind you - 3" spindles will have the control arm hanging below a 15" wheel, which has its own set of risks.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I have the McGaughy's 2.5 drop spindles and 3 inch drop coils. The original owner had the oem rally wheels installed when i bought the truck. He definately had lower control arm clearance issues. His "fix" was to gring of a small portion of the lower control arm for clearance. When I took over the buikd...I ditched the rally wheels...sold them on craigslist.org and put the money towards the set of 20" wheels that are currently on the truck. If you only want a small amount of drop and rake look...stick with cutting a coil, stock spindle and drop shackle out back. If you want the rally look, then consider buying aftermarket rally wheels that have enough offset to run drop spindles and springs. Vendors such as classic industries out of California sell rally wheels. I believe American Racing also has a rally version as well.
BTW. I corrected the hacked lower control arms by welding in reinforcement gussets. I haven't had any issues with McGaughy's when it came to inquiries or quality. Im lucky...there's a mcgaughys shop less than 2 miles away from my house. Bell tech, air bag it...etc. all manufacture their spindles in China. Im sure mcgaughys does too due to cost. I dont even think Western Chassis has a foundry in the U.S. you will need to specify the thickness of the brakes when ordering the spindles to insure you get the correct pair. I ordered from McGaughy's as they know what is required since they build their trucks down the street from my place. Like I said before...I haven't had any fitment issues and they are always glad to help me with my questions. We have been discussing the next phase of my build....body drop.
MikeB
North Texas
I If you want the rally look, then consider buying aftermarket rally wheels that have enough offset to run drop spindles and springs. Vendors such as classic industries out of California sell rally wheels. I believe American Racing also has a rally version as well.
Haven't been able to find any 7" rally wheels, stock or aftermarket. Lots a 6.5" van wheels available, but they have 4" backspacing, which is almost as much as the 8" rallys with 4.25". Wouldn't mind having some 7" 5-spoke Torq Thrust style wheels with approx 3-3/4" BS, but really don't want to spend the money. However, selling my my 8" rallys might pay for half the cost. Seems like they are becoming worth more every year.
I may start with cutting a coil out of my existing springs, or maybe new $60 Moog springs. And if I have fender clearance issues with my 255/70x15 tires, I'll just have to bite the bullet and get some 235s. Also may have to get some shorter shocks. ??? Wouldn't you know I recently installed new KYBs front and rear. :(
Still like the idea of lowering with a dropped spindle, but it sounds like they'd work best with 17" or larger wheels.
RangRayy
Kansas City, Missouri
ryan
r10
any updates on this?
MikeB
North Texas
The only truck 7" rally wheels I could find were expensive and in terrible condition. Turns out the father of a guy I know has a ton of square body parts, but he doesn't have a single 7" rally wheel.
I was hot to go on lowering the truck a few months ago, but now I'm not in any rush. I am starting to buy tie rods ends and ball joints, so may just install drop springs while it's all apart.
RangRayy
ryan
r10
Well I'm going with 6.5 rallies up front and 8 in the rear. I'll gladly give you any of my rallies if you're wanting a 7. I'd have to double check my stock rally wheels but pretty sure they're 7 not 8.
Rusty Nail
Rusty
350sbc
Air powered cut off wheel with the stock spring in a bucket of water is the way to go. :imo:
Drop spindles are for cars.
77MarshallR
