Dropmember - Need options
GO-N-BRK_84
Washington State
Jeff
C1500
400ci
Hey all!
Looking to order a front dropmember to put in over the winter, get that layout looking correct. Porterbuilt has a really nice setup, but with everything required I was quoted $4,700. Choppinblock has a nice setup as well and looks to be around $2,900 - but still requires purchase of a Mustang II rack...maybe another $300. Are there any options out there that make use of stock steering? Mines nice and tight, really don't have any complaints. Neither of these 2 options have any sort of "upgrade" path. For example maybe I just purchase control arms and later upgrade to dropmember? No the dropmember uses different control arms.
Am I missing something obvious? I really just want some control arms to correct geometry and a cross member with a bit more clearance.
Big Chip
Michigan
Kevin
C35
I think you'd be happier with the rack and pinion as opposed to the stock setup. On mine the geometry is not good even with just a 6" drop. The pitman arm hits the tie rod and there's a bit of bump steer. It's not terrible but it's there. I've been eyeballing the Porterbuilt with the rack to try to correct some of that.
GO-N-BRK_84
Washington State
Jeff
C1500
400ci
Just thought I'd keep this thread I started up-to-date! I pulled the trigger on the PB Fab version 7, level 3 airbag dropmember kit:
- New crossmember
- Upper & lower control arms
- Rack & pinion steering upgrade
- Small block chevy motor mounts
- New shocks to match the kits mounts
- New transmission crossmember
- Kit is very complete, completely bolt-on, comes with all hardware even all new steering linkage joints and shaft.
They are currently 10-12 weeks out for production which is a little rough, but should give me plenty of time to prepare (procrastinate) the truck for the kit.
I'll post pics when all the bits and pieces arrive!
Big Chip
Michigan
Kevin
C35
- New crossmember
I'm interested in this. It's pricey but I think it solves a lot of problems that I've discovered trying to mix stock and modified suspension together.
Grabbit
PNW
Frank
R10 Suburban 2WD
I know the OP went with the PB fab crossmember and I too am looking at all options to lay out the front as low as possible. With that said, I thought I'd bring up a front end setup I came across that; while it isn't a cross member per say, it is a way to get lower than most of the other control arm and bag combos I've seen on the market that use the OEM crossmember. I found the Chassis Fab front end kit which uses the stock cross member but has you cut off the OEM spring pockets of the OEM cross member and weld on a new upper control arm and bag mounting plate that seems to get almost as low as the crossmember setups like the PB, GSI and others. From what I can tell it moves the upper bag mount up and at an angle that can get the front lower than using bag mounting plates on the stock upper spring pocket. For both upper control arms, lower control arms, shocks and mounting plates (all while retaining stock steering components) it comes to $1600 which is pretty comparable to other control arm and stock location bag mount setups but a lot lower than a full blown cross member setup. Check em out.
https://chassisfabsuspension.com/co...kits/products/63-87-c-10-front-suspension-kit
Twistedwhisky
