Driver4r's Monte
Driver4r
Nebraska
Trevor
k10,c20
Ok, i figured ide start a thread for my monte progress.
As of now it is:
305(rod knock)
th350 w/ lockup
10 bolt originally 2.29:1's
Plans:
350 w/ vortecs and L79 cam
th350 with shift kit
Headers hooked to glasspacks that dump
Gear swap to 3.42's
Driver4r
Nebraska
Trevor
k10,c20
So today and yesterday ive been swapping the gears. Im putting a 7.625 carrier(out of an s10) with 3.42's in place of the original 7.5" 2.29's it had originally. ******* PITA. Was going great till i was reassembling. Put the s10 side spiders on the axle shafts and spun the axle shaft(click click click) ........damn, wrong spline count.... So then i swapped in the monte side spiders, slide them on, put the idler spiders in and ran the crosspin in. Theres a HUGE gap not quite 1/8" between the idle spiders and the carrier. SO then i pulled those out and tried the s10 idlers, they were to FAT to fit. So now im in a bind.
My options:
1. Shim the **** out of it(idlers and side spiders)
2. New axles( get 28 spline)
3. Find a spider set for a large window/small window 7.625 carrier for 26 spline.
The cars tore apart in my driveway and i need to get it back together......
Anyone have any ideas??????
MrMarty51
Eastern Montana
Martin
OH FUGGGGggg, run the 2:29s, them`ll give You some real good speed, especially with a non OD transmixer.
Install a manual trans with then 2:29s, 90 at 3000 rpms.
Driver4r
Nebraska
Trevor
k10,c20
the 2.29's are out of the housing and the 3.42 pinion is in......... Im thinking ill try and get another s10 axle............ this time with a 7.5 carrier instead of a 7.625, even though its stronger. FUCKKKKK. I really dont want to dish out 260$ for a pair of axles, and i cant find a spider kit. I could space it for now, and go till i have the funds, or she blows.
Driver4r
Nebraska
Trevor
k10,c20
Update: Found another differential. Its a 26 spline 7.5" carrier out of an earlier s10(86). To bad i cant use the gears on it XD. 4.11's wouldnt do to good in a car with no overdrive and 26" tall tires.
Driver4r
Nebraska
Trevor
k10,c20
ITS TOGETHER!!!!!!!! YAYAYAYAYAYAYYAYAA. after it took awile to find out that they are reverse thread, it went quick
Driver4r
Nebraska
Trevor
k10,c20
Mother of GAWD.........today isnt fun.
Got put together yesterday, sealed the cover, painted it.
Well today i filled it full of gear lube. After i got that done i put the driveshaft up in plane and was tightening it up when.......... the pinion had play and was moving up and down.....****. So i pulled the front all apart and compared yolks, they were the same. So i put it back together and tried it again, still had play. Pulled it apart AGAIN, pulled the seal off and pulled the bearing out, then pulled the crush sleeve, the sleeve hadnt ever compressed, so i put in the crush sleeve that came on this pinion, put the bearing on, tapped the yolk on to set the bearing in, tapped the yolk out, put the seal in, then put the yolk on for the last time, tightened it up. I started thingking to my self, YAYAYAYAY no play. Guess what. NO BACKLASH EITHER, ****. so now i have to pull the carrier out and play with shims again.............
Oh boy is this fun.......
And that rear cover was a bitch to get back off, it was sealed GOOD.
Driver4r
Nebraska
Trevor
k10,c20
I know you all love pictures as much as me. Heres some pictures of my progress.
Front view
Rear View
Wee 305
Interior
Open axle
Side View
New Pinion/Old Pinion
New Ring/Old ring
Another veiw
Spare Parts
My hand after the carrier tried to eat it when removing it
She looks good with the Hurricanes. :grd:
Sent from my iPhone using Tapatalk - now Free
Driver4r
Nebraska
Trevor
k10,c20
If im going to run these, i need to find 2 15x8, or 9"s. I can run 235's fine on these wheels. But i need a little wider for 295's. These are 7.5"s if i remember right. And i have 2 whiteletter tires for the front.
MrMarty51
Eastern Montana
Martin
OH Yeah, them gears has sharp teeth.
Good to see it is going back together. :popcorn:
Driver4r
Nebraska
Trevor
k10,c20
My shim sets should be getting here today
Driver4r
Nebraska
Trevor
k10,c20
Its together, it runs, it drives. Time to pull the engine XD.
Driver4r
Nebraska
Trevor
k10,c20
Do you think 63-82 vette headers will fit my monte? I have 2 sets........
Lol, I recently destroyed a 3.73 ring gear because I forgot the bolts were reverse thread. They were no match for my impact.
K5Chris
