driver side lower control arm
cbrodine
NW Ohio
Collin
C25
I'm looking for a driver side lower control arm for my 73 GMC C25...Some rust is fine, just no heavy pitting or holes rusted through. Ball joint can be shot, doesnt matter as I'd replace it anyway. I bought a new one but cant use it because I am unable to bolt the shock to it because there isnt enough room for the nut...weird I know. Please help me out and let me know what you have...thanks!
Ok, esplain this shock not thing again? I don't get it. You should be able to use the CA you bought.
I would be quite sometime, but I'll eventually have a 86 C20 LCA. I just can't take off the truck right now and have to keep it as a roller.
cbrodine
NW Ohio
Collin
C25
HotRod...when I try to bolt the bottom of the shock to the new LCA I can slide the bolt in through the shock mount and shock, what I can't do is put the nut on because there isnt enough room for the nut. On the LCA (where the nut should go) beside the shock mount tab should be an area that is slightly recessed or bent in so that the nut has a place to be. On my new LCA this area is not as recessed as an older original LCA, so with the bolt in place I am unble to put the nut on. I hope this makes sense. This is why I want another original LCA, I will just media blast it and powder coat it like I did the passanger side. You have one available?
I think I know what you're talking about. A bit longer bolt should cover that. Kinda sux though. That's why many people like myself only like to buy OEM parts and to hell with new aftermarket ****.
If I have one, it'll be quite some time before I can get it. I'm talking, maybe mid summer or so before it'll be available.
Snips71
