driveablity, carbs, gas tank... blah
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
Ok, so I posted before that my truck has a Holley 650 double pumper which we agreed was too big for a stock 305. It runs rich and dies at stops. I went to fill it up for first time yesterday night and I could only get about 1/3 of a tank. Reading the forums for about an hour last night, I concluded that it is probably b/c of the tank vent valve, which if Im correct is behind the drivers head lights (???). Would this also create driveablity issues as described? I dont believe that the carb is set correctly for idle speeds, as in it is too low. I dont have a tach, but looks like I might get a cheap one this weekend. Also, a vacuum gauge/pump.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I know from an old friends experience who put a non vented cap on an old Chevelle. A couple days later the engine died and there was so much vacuum on the tank that it collapsed looked like a beer can that had been stomped. It only held five or six gallons after that. Same could happen if a vent valve was plugged.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
I got under the truck and the tank looks fine. I know I cant see much of the top besides the lines, but it looks fine up there too.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I feel like we've talked about whether or not you had an evap canister so forgive me. If you have one, and it's connected, then that's your vent system right there. The system generally consists of the appropriate gas cap, canister, canister filter, and purge valve. If something's plugged like a line or the charcoal canister, that can be an issue. Also, a clogged filter (bottom of canister), a bad gas cap, or a vacuum leak somewhere can be bad. Most evap problems result in gas smells or vacuum leak related idle/driving qualities.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Umm. Well I know things like the purge valve have been removed. This engine has aftermarket valve covers. Im not sure if the gas cap is original, its a faded yellowish color. I should prob get a new one. I also know this truck doesnt have cats. Sooooo good question as to what else is off of the truck.
But, Im trying to figure out why it would only allow me to put in a 1/3 of a tank of gas before it spit it back up the fill tube. And it seems that I have seen the most likely cause being the gas tank vent valve....... which Im not sure if that is on the vehicle or not. When I purchased the truck, the tank had more gas in it. It seems like what happens is the hotter it is, the vent valve blocks up more. And it is about 15-20 degrees hotter than when I purchased the truck.
Im curious as to if the vent valve is blocked/plugged up, would it create an over rich running?
Gah, I need to drop an LSx engine in this thing... something with fuel injection. :(
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I don't think it would affect driveability that much on an older vehicle. A vacuum leak is not a benign occurrence, and any known ones should be dealt with, but your issue when fueling definitely has something to do with how the tank is venting. I would check for a clogged line between the canister and the sender. The lines should be labeled on the canister if it's still there. The trick I've seen is to blow in it and see if it's clear. I don't know how good that is if there's crud, and it blows back into the sender, but I don't think it'd hurt. You could also check the canister for clogs by doing the same thing. Just put a hose on the inlet and see if air comes out the other side. I think in the carbureted trucks, the valve was mounted on top of the canister so it should all be there and connect to the carb per the emissions diagram. If you didn't want to fool with it, you could also disconnect the line that goes to the sender, install an inline filter, and altogether delete the evaporative emissions system.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I used a differential breather on my tank. Right, wrong or indifferent it works. I had a few left over ones just make sure it's above the tank.
74 Shortbed
Anything will work as long as it's kept away from the elements as much as possible, can always use a mini breather on the end too.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yup.just gotta be able to breathe it ain't rocket surgery.
Bhardiman1
