Door binding on fender
Erik
Charlotte, NC
Erik
I have a 1974 Cheyenne c20. The passenger side door is binding on the fender when I open and close it. It operates, but rubs. There is a little space between the door and the b pillar, so I might be able to slide it back a hair, but not much. Otherwise I guess I would have to adjust the fender forward?
Is there a way to slide the fender forward 1/8 inch or so, or do I need to try to slide the door back? Can anyone walk me through either of those procedures?
I’ve fixed a bunch of little nagging issues on my truck during this Coronavirus lockdown, and this is the one left. For now.
Erik
Charlotte, NC
Erik
It looks like I might need to remove the fender to access the bolts. Is that correct?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
access to the bolts sucks but can be done. check the bushing in the hinges before making any adjustments. they need to be replaced most likely.
Erik
Charlotte, NC
Erik
What bushings do you mean?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Fender or door.
IMO, the fender bolts are easier to get to, and you wouldn't risk scratching up such a nice truck, but you'll be moving the rad support, inner fender well, grill, and everything else with the fender.
The bushings he's referring to are on the door hinge pins for the 2 hinges.
Those bushing eventually give out sooner or later from carrying the weight of such heavy doors.
Also greetings from salisbury NC neighbor:wave:
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Lmc diagram. Item #10 hinge pin kit, $9.95
Erik
Charlotte, NC
Erik
Thanks!
Keith Seymore
Motor City
Keith Seymore
4.3L
You also might be able to cheat it a hair by moving the bottom of the fender out (crosscar).
You can do this by adding a shim at the lowermost attachment of the fender dogleg. You can also stick a big prybar into the bottom of the fender via the door opening and give it a good pry outboard but some folks might find that offensive.
K
WhatsUpBeaches
