Fightin Rooster
- Dec 28, 2020
- Mission Viejo, CA
- Greg
- C20
- 5.7L 350 gas
Hello,
I'd like to install pin switches in the doors of my 74 C20 to activate the interior dome light. There are none installed now.
There is a plastic cap over a hole in the door frames right where you'd expect. I removed the kick panels with the side vents and have access to the back side. The problem is I cannot reach all the way to the door frame as there is sealed structure which is essentially the A pillar continuation.
I have installed pin switches in doors before and I needed to get to both side to fasten the nuts and set the depth.
LMC sells 36-0622 COURTESY LIGHT SWITCH CHEVY GMC 73-84 theoretically specifically for this however it looks like it only bolts into the front, doesn't have a depth setting, and looks kinda long from their drawing.
Then of course, running the wire will be an issue but I'll handle it.
Does anyone have experience this part, or a recommendation, or advice?
I'll also be running speakers (and maybe power windows) in the doors. Perhaps if I put a 1 inch hole for the wires very, very close to the pin switch location, I could use that to access and fasten the rear pin switch bolt.
Thanks
Thanks
