Dipstick lengths
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Should the length of the dipstick be the same whether it's on the driver or passenger side of the motor?
Thank you.
Brandon
Nope. Besides the dipstick's location, GM made them in different lengths for each depending on the year an application. The dipstick just has to be a match for the tube.
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
If I added a larger capacity pan, dipstick should be the same size, right?
I had the stock size for the 350 (5 quarts required) and got a new pan that says it's 1 quart larger, wondering if the dip stick is still accurate.
CSFJ
Lol. Think about it. If the pan isn't larger, then it would be like overfilling a stock capacity pan.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Okay couple more questions: I just put this motor in my truck: http://www.jegs.com/i/Chevrolet-Performance/809/10067353/10002/-1?parentProductId=
With it I got a drivers side dipstick tube plug as I wanted to move the dipstick to the passenger side. Well the tubes aren't the same diameter, so I went to the parts store to find one that was the same. Made some adjustments to the tube and used my old dipstick (prob not the best idea but time was seriously of the essence and I needed to get it wrapped up). Per the details of the motor, it is a 4 quart pan. I put 4 quarts of oil in the engine, about 1/2 or so in the filter and about 3/4 (12 ounces) of a bottle of zinc in as well.
What is the TOTAL capacity of the motor so that I can get a proper measurement on my dipstick? Oil pressure has been very good, but don't want to use that as my gauge.
Please go easy on my as I'm still learning about engines.
Thanks in advance.
Brandon
adamj
Colorado
Terrence
V20 Suburban
5.7L TBI
A 4 court pan is the stock size for the 350, and the total the engine takes is 5 quarts.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
I thought so too! So when I change the oil this weekend, I'll put a total of 5 quarts in right? Then I'll measure with the dipstick and adjust the markings if I need too. Thank you.
A little less than 5 quarts if you run the short-body oil filter.
You know the correct dipstick and tube (chrome) can be bought at most parts stores for like 8 dollars, right?
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
I have a full size filter. And yes I went there to get the dipstick that I currently have. The issue is that the driver side requires a larger size tube than the passenger side. Hence, I had to find one that was the correct size.
MikeB
North Texas
The issue is the driver side requires a larger size tube than the passenger side. Hence, I had to find one that was the correct size.
Don't forget that each side is different -- both tube and dipstick. And passenger side dipsticks and housings changed sometime in the late 80s or early 90s as I recall.
P/Ns below are for GM steel plugs for both sides of the block. They are included with the basic GM Goodwrench crate engine.
passenger side: 9421743
driver side: 14091563
3dbello
