detroit locker install-14 bolt FF
colonel mustard
louisville ky
steven
k5 blazer
Good morning all,
I picked up a Detroit Locker at the lima truck jamboree a couple weeks ago and will be installing it this weekend. its going on a 14 bolt FF.
any body have any tips or tricks they wanna share with me?
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I'll be watching this. I also have a 14 bolt ff open diff on one of my heaps.
nvrenuf
Mobile, Al.
It's a super easy install. Are you familiar with pulling the carrier out of a 14 bolt?
The only real trick is the Detroit assembly is spring loaded so leave the assembly bolted together until you have it inside the reassembled carrier, then remove the bolt / all thread that holds the Detroit together.
colonel mustard
louisville ky
steven
k5 blazer
I have not taken a 14 bolt carrier out before.
does the carrier get reinstalled before the locker bolt is taken out?
nvrenuf
Mobile, Al.
Prior to reinstalling the carrier back in the housing - once the carrier halves are bolted together (via ring gear bolts) then remove the Detroit retainer bolt.
The carrier has threaded adjusters in the housing outside of each carrier bearing, once you remove the retainer clips just MARK and count the number of turns it takes to release pressure and remove the carrier. Once you put it all back in just tighten the adjusters back the appropriate number of turns, install the retainers and you're good.
Don't forget to start with pulling the axle shafts out about 4"-5" to get them out of the carrier. Oil will spill.
Beware, the carrier assembly is HEAVY and will do it's best to mash fingers when it comes out!
colonel mustard
louisville ky
steven
k5 blazer
That’s fantastic info man. Thanks for the tips. That helps a bunch.
Nonstop
Ca
Nick
K2500
Only other info I could add is to mark the bearing caps (side to side and up) and the diff case halves. It is a really easy job!
Bob Igram
Grants Pass, Or
Bob
Im curious here, whats the average shop time needed to install a locker in the 14Bolt FF? i ask because if i choose to buy one, id like to have some idea of labor time for an experienced installer? Thanks in advance!!!
colonel mustard
louisville ky
steven
k5 blazer
Couple hours
87R10_Cruising
