Dash pad repair
adriner
Out in the sticks, PA
Adam
k25, c20
350 nv3500, 6.2TD th400
If you a cheapa$$ (or thrifty as I like to call it) like myself you'd rather spend 300 bucks on something worth 300 bucks and not a dash pad. I came up with a way to make your own and only have about 4 hours into it. My Initial budget was $20 and I didn't even spend that much! Here's how I did it
Step 1 - remove old dash pad
Step 2- cut off existing vinyl and foam (or burn it off with an acetylene torch like I did) and get down to the metal surface
Step 3- buy a can of spray foam and spray a small layer of foam over the metal. Getting the thin pieces around the defrosting vents is tricky. Let the foam dry
Step 4- once dry cut the foam into desires shape or use an airboard with 80 grit to cut and shape it. Once again this is very tricky and also REALLY MESSY!!
Step 5- get a piece of vinyl and cut and sew it to fit. Yes it is a pain in the balls but its doable
Step 6- once you get it fitting the way you like take spray adhesive and coat the dash then stretch the homemade cover over top
Step7- wrap the ends of the new vinyl up underneath the dash and some how fasten them, i used short panhead sepf taps. But be creative and do itthe way you want
Step 8- install new pad and spend the 280 bucks you got left on somethin else
Ill have a pic up tomorrow
muddyman184
Phila
steve
90 AND 82
K5,K20
Cant wait to see this
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
i guess hes still waiting for the glue to dry
hinkv10
ct
craig
v10
I'm really want to try this myself. Pics on how you screwed the cover onto the pad would be helpful. How much overlap on the sides and how you sewed it up would be helpful. Thanks
MrMarty51
Eastern Montana
Martin
I think a hand stitched dash cover would be great.I would like to see pics, too.
chubble
Eastern, NC
Custom Deluxe K10
I'm happy to see someone else experimenting with the dash pad. I did something along these lines with mine a couple weeks ago.
oopsman_09
Nampa, ID
Aaron
sierra classic c1500
so doing this
We don't pull no punches around here. Cheapass works just fine. Of course that depends one's definition of Cheapass. I won't skimp quality to get by cheap. But this certainly looks well enough to be much cheaper than the alternative. The other advantage is customizable options. This is great.
Repuatation Given !!!
Nice Addition to this thread. Is your instruction about the same??? Anything different or variable you might add?
Thanks for the Pics. Reputation Given here too. So your GMSB Cherry got popped !!!
Self tapping pan head screws, got my attention. :D
adriner
Adam
k25, c20
It's by no means perfect but I'm happy with how she turned out. You can see some loose edges but that can be tucked under during inylstallation
Villano
