Dash clips- how do you get them in?
Dano500
Houston, TX
I find lots of threads about pads, but not how to get the clips in. I have this pad from summit and it is of poor quality over speaker areas. Another problem is metal where you are supposed to install clips seems buried and inaccessible. I tried to bend a tab on one clip and it broke. Do I need to cut most of that out?
Thanks,
-Dan
Dano500
Houston, TX
I’m assuming this is correct? The short tab goes into slot right under it?
Washington
Very carefully and then try to keep them from popping out when installing the dash. Iirc I bent a couple so they clipped into the dash pad tighter.
Dano500
Houston, TX
Thanks, I ended up having to dig in at an angle and rotate them in. Oh, and lots of trimming urethane.
hoagster
California
K10, 1500
5.3l
Brothers truck parts has a video on how to do it. This is not a recommendation for Brothers however!!
Bloodhound1981
MA
Rusty
C-10
I feel like things somehow got worse after Holley bought them.
Jeff Lewis
Missouri
Jeff
Do not expect an aftermarket pad to fit perfectly. Close is as good as you can get it. Expectations reduce joy.
adhkjashda
