Dana 3/4 vs 1 ton?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It's a lsd or posi yes. Open until one side starts to slip then the other side starts to engage. I snapped shafts all the damn time. I was about to upgrade to a 60 when I flipped it. It had a bad ass 454 too and I never was shy of wide open and we don't have mud. All Rocky mountains lol. Not as forgiving as mud.
With clutches or mechanical locking components, I should of elaborated.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok good thing I have spares then lol. And 4 wheel disc to help from tossing a rear axle out. Then again if your not breaking stuff your not trying hard enough lol
454-k10
CO
Rodney
Yea, I thought that until I flipped mine.
Battlac40
New Mexico
James
K1500 Sierra Classic
Anything to know about 71 3/4 dana's ?
I'm picking up a 76 tomorrow with 71' 3/4s under it..
yevgenievich
Viktor
sad
very sad
less sad
Early 3/4 tons received a full floater in the rear. And front 44 might have desirable flat top knuckles for cross over steering upgrade
Battlac40
New Mexico
James
I understand that the bearings in the d44s are bigger than the 1/2 tons??
yevgenievich
Viktor
sad
very sad
less sad
I think only the early years around 75 and earlier had difference 1/2 vs 3/4 on the spindle size and the bearing. Later was just being 8 lugs and larger brakes.
454-k10
CO
Rodney
If they have external lock out hubs the inner bearing is bigger. The lock outs have 6 bolts mounting them to the hub. The bolts like to back out and break.
454-k10
CO
Rodney
The later hub bearings are the same 1/2 to 3/4 ton d44 to 10 bolt.
4WDKC
Southern Florida
Kacy
this makes it a mf to find replacement bearings, I have a set of these spindles and am swapping them out for the smaller easier to find bearing.
Battlac40
New Mexico
James
What about the 71'?
Battlac40
New Mexico
James
Good INFO Guys You Kick ASS
:Jedi:
454-k10
CO
Rodney
Actually the spindles are the same and you can get bearings at rockauto or lmc. The inner race that rides on the spindle is the same diameter. I have a set of each kind of hub and have switched back and forth without issue. Swapping the spindle won't change anything. If you have a set of newer hubs you can put them right on.
johnalen76
