Dana 3/4 vs 1 ton?
Battlac40
New Mexico
James
K1500 Sierra Classic
What is the big difference in between the 2?
Growing up I always only herd about the 3/4, now it seems everybody is about 1-tons.
Want to convert for towing / better bearings.. (12bolt in the back 10bolt in front corporate)
What are the differences in between the D44s and D60s?
CSFJ
If we're only talking front axles, the d60 is massive compared to the d44. The d44 was designed as a half ton axle. It was adapted to eight lugs when the manufacturers decided that they didn't need a separate axle between thee two. Everything about the d60 is heavier than the d44.
4WDKC
Southern Florida
Kacy
if you are swapping to 3/4 or 1 tons you wont have a 12 bolt, 3/4 and 1 ton got a 14 bolt as standard equipment unless you got the dually with hd option to upgrade to dana 70 rear.
Battlac40
New Mexico
James
And the difference between semi and full floaters?
What do you mean a separate axle between the two ?
What do need to switch to the d44s from the 1/2 tons?
Should I hold out for 1tons?
yevgenievich
Viktor
sad
very sad
less sad
14 bolt semi float is essentially similar to a 10 bolt in design except substantially stronger(9.5" vs 8.5"). Full floater is even larger(10.5") and all wheel load rides on a separate bearing that axle turns.
For the front 3/4 axle does not really offer improvements in strength over 1/2 version for exception of 8 lugs and bigger brakes.
All depends on the purpose for the truck
hirschdalechevy
norcal
rich
k-30
One more thing about semi float vs. full float , the pinion in a full float rides on three bearings , (two in front and one in back) , and semi has only two , (both in front). Full float blows semi out of the water in all ways.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Agree but I’ve seen quite a few FF with broken inner support bearing boss’ broken. Which pretty much renders them useless. Not being Contrary Pete here, just something to keep an eye out for when buying one.
454-k10
CO
Rodney
Unless you're seriously 4 wheeling you don't need a d60 up front. A d44/10 bolt is sufficient. To make a 6 lug d44 8 lug you have to swap the outers. Caliper holder/backing plate, caliper, hub and rotor. Extremely easy. The lock outs are the same 6 and 8 lug.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’ll throw this tid bit in too. 89-91 Blazer and Burb 10 bolts have 30 spline axles. Well 89 is 50/50 from what I’ve found. Fronts and back axles have them.
454-k10
CO
Rodney
I bashed my last 14ff and it took everything I gave it, laughed and called me a ***** lol. 500 lb axle and everything is heavy duty. I got my first sf axle and interested to see how it holds up. This truck will only see the street so I'm leaving the axle, but if I was 4 wheeling it I would swap a ff. They're everywhere and they're cheap.
454-k10
CO
Rodney
30 spline at the diff like a d44? So can you use these shafts on a d44? 10 bolts were 28 or 29 I can't remember, but the d44 inners were 30. All the outers were 19.
The inner spline count won't effect swapping 6 to 8 lug though. That doesn't matter.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Inner spline is 30 on the later 10 bolt. I can’t say if it’s the same as D44, but the axles are beefier then the 28s same with the rear axle shafts. I have a 91 front with an Eaton 8.6 posi up front and a 12 bolt and posi in the back. It’s not a crawler, more mud and my theory is the posi will slip before **** breaks. Then again I have them set pretty tight. Lol
454-k10
CO
Rodney
I had a Trac lok in d44 front and would snap shafts all the time .
454-k10
CO
Rodney
Is that a positive engagement device?
It's a lsd or posi yes. Open until one side starts to slip then the other side starts to engage. I snapped shafts all the damn time. I was about to upgrade to a 60 when I flipped it. It had a bad ass 454 too and I never was shy of wide open and we don't have mud. All Rocky mountains lol. Not as forgiving as mud.
Bhardiman1
