Cruise control
greaves
Wilson
Glenn
Does anyone have good pictures of what the cruise control assembly/Servo looks like on a 1984 K10. The PO just chopped off the wiring and vacuum hose at the firewall and everything is gone. Trying to make sure I get the right parts ordered and from the salvage yard. Any help will be appreciated.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
From what I can tell and remember the cruise vacuum actuator just mounts to the throttle and tv cable bracket, if you have a 700r4, probably the same for a th350/400. Then it has a little adjustable linkage that connects to the throttle linkage on the carb, then a single vacuum hose(I think) "then maybe 2 or 3 wires in a single harness?"
Someone else will for sure be able to help on the electrical side, I just removed mine and never looked back. Sorry for the old pictures.
Up by the brake booster.
3dbello
