crossover steering with no lift?
Affende
ColoRADo
Affende
83 and 84
C1500 and K3500 3+3
250 and 454
Its no secret that push pull steering is .... effective. It is not, however, perfect.
the front end of my truck needs all new steering linkages, the power steering box is sloppy and leaking, and i want to put in a XJ steering shaft ..... i would like to go with a crossover steering setup ... less bump steer, less stress on the parts, etc
My D60 needs new ball joints, and probably new king pins, as well as a good reseal ... so i plan on rebuilding that 100%. while its apart, it would be a great time to upgrade the steering and i will be swapping my front sagging 3 leaf springs for 4 leafs (added a welder and tools, and it has a 454 so i dont *think* i will be too stiff).
Ideally i would like to do this all in one go ... collect the parts, rip it out, and put it all back new.
SO...... can you run crossover steering with no lift (but new slightly higher load springs)??
lifting is a last resort ... dont need it, dont like it, dont want it.
opinions? experiences?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I can't write on a check on it but I believe you can. The anti-sway bar will have to go but with your big springs you may not even notice.
Don't skimp on your shocks, they do more to minimize body roll than one would think.
Too bad these trucks didn't come from factory like this. It's a pretty profound difference.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Also forgot to mention, you would need a 2x steering box. If you have done any research I'm sure you know about that. Not a big deal, just another thing to think about. They are cheap at the wrecking yards...
SDJunkMan
Black Hills of South Dakota
Jeff
I keep seeing references to crossover
Crossover steering is new to me, but makes good sense. What is a 2x steering box? Do they have the same splines as the stock box and would use the same steering shaft?
yevgenievich
Viktor
sad
very sad
less sad
2wd steering box. I believe there is very little space available for cross over steering with no lift. Engine cross member is in the was
SDJunkMan
Jeff
I gotcha. I am planning a 4" lift, so I should be good with stock box if I go with the crossover steering?
CSFJ
By stock, do you mean stock 2wd steering box? If so, then yes.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
The 4wd box has asymmetrical splines so you can rotate the steering arm to point forward.
Some times the engine cross member can be trimmed slightly... other times it's a no go. I'm not sure why they aren't all the same. Perhaps making millions of these trucks in different plants has something to do with that. A good option is the engine cross member offered by ORDs...
Wouldn't be difficult to make one of these. I would jump in with both feet and I think I could even improve on the design.
http://www.offroaddesign.com/catalog/enginecrossmember.htm
While I'm here, or there...
http://www.offroaddesign.com/catalog/Dana60crossover.htm
CSFJ
Wasn't aware that you could rotate the arm. Thought that was the reason for the 2wd box. I know the saginaw boxes they used on jeeps had a double width spline in one point of the shaft, so it could only be clocked one way.
idahovette
Weiser Idaho
Perry
K20-K10
On all the 73-87 GM 4x4's I have worked on, the pitman shaft has a few splines and a notch that a bolt goes through to attach the arm to squeeze the arm tight to the shaft. Not splined all around and the pitman arm goes on one way.
SDJunkMan
Jeff
No, I meant a stock 4WD box. So even with a lift I need a 2WD box?
Not sure if I will ever do the crossover conversion, but would hate to replace the steering box, then find out I should have used a different one.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
No sorry that came out wrong. The 4wd box has asymmetrical splines so you CAN NOT rotate the arm.
This is why we use the 2wd box. Whew..
Yes this is correct.
SDJunkMan
Jeff
The steering on my 78 is pretty sloppy, but I am hoping the jeep intermediate shaft will fix that. If not and I have to replace the steering box, will a 2WD box work with the stock setup, and then it will be ready if I decide to change over to crossover steering?
CSFJ
The 4x4 box clocks the pitman arm in the wrong direction for the crossover. The 2wd box puts it right where it needs to be.
Taco main chew
