Crewcab LWB to SWB conversion
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I have seen multiple 2 wheel drive 3/4 ton crews but I have never seen a 3/4 4x4 crew
the 3/4 ton 2 wheel drive crew cabs used the same frame as a 1 ton
2quick4u
West Texas
Lane
c2500
Kleedus,
Yes, I've seem several 3/4 2wd crews also. No cab lights, single rear wheels. My 3/4 frame measured a full 8" in height, and .250" nominal thickness. 1/2 ton is 6-1/2" in height, with a .180" nominal thickness. (at least behind cab, where I grafted the two together)
I'm surprised at how many of the parts are the same/interchangeable between the two.
Still moving forward, and will keep posting findings and obstacles.
MadOgre
NA
NA
NA
NA
NA
I guess the 1 ton frame is why the front end components are different then?
3dbello
