- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
OK time to try to get more truck fundage! I cant find the particular driveshaft I need at all, so I'm going to part the front and rear 1/2 ton axles out and probably have to buy the 3" tube to make my driveshaft longer (more expensive than cutting a LWB d-shaft down). Here's a list of parts to start with, and a ballpark value. I'll know more what they're worth once I get them out and clean them up. Everything will require buyer to pay shipping:
3.73 Motive Gear ring & pinion for 73-87 Chevy front Corporate 10-bolt axle: $50
3.73 Richmond Gear ring & pinion for 73-?? Chevy rear 12-bolt axle: $65
Factory Limited Slip posi for 73-?? Chevy rear 12-bolt axle: $40
Factory Open carrier, complete with sides & spider gears, for 73-87 Chevy Corporate 10-bolt front axle: $30
Front Axle Shafts-
Inner long side: $40
Inner short side: $30
1- brand new outer stub shaft: $40
Other outer stub shaft is in bad shape, not for sale except as a trail spare for cheap.
Any combo of above, or all, make offer!!
Rear Axle Shafts-
Each $30
Both $50
Dana Spicer locking front hubs: $30
Front spindles, hub/rotor assemblies, calipers, caliper bolts, steering knuckles, cover+bolts: $Make Offer!!
Rear drums (like new), wheel cylinders, brake hardware, backing plate, complete parking brake system from pedal in cab, cables, brackets; cover+bolts: $Make Offer!!
I think you'd have better luck getting hits on this sale if you'd put a seperate ad titled properly in the For Sale section, rather than this misc. cluster fugg of several items. Also, you have these priced in parts. Does this mean its not assembled ready to bolt in? I think you'd have better luck selling them complete with the description of what's in them. I damn sure wish I was closer, I'd take them. Shipping kills the deal though. I only need the rear end for the 12 bolt and LSD upgrade, but I'd take the front too for a back up, cuz I know its only a matter of time, I'll break mine. Mine already has 3.73 gears so it'd be a great purchase for me.
