- Apr 11, 2017
- kansas
- Rick
- c20
One of the other threads someone is talking about hand sanding their frame. I happen to have a sandblaster big enough to do a frame or a car,just not enough compressor to run it for long periods. So here's where my broken brain figured,can I make a V8 small block into a 4 cylinder compressor. My thinking is make a intake gasket out of copper or aluminum copy a stock gasket but with no intake port openings. Pull all the rockers on 1 side put really really light springs on the exhaust valves,plumb all 4 spark plug holes through check valves into a common manifold which will plumb to an air tank with BOV to regulate pressure. Down stroke,vacuum will open exhaust valves and fill the cylinder,upstroke will push compressed air out of the cylinders. I know I'd have to put iifters in the lifter bores,and tack them. What am I not thinking off? Run on 4 pump on four it ought to make all the air I could ever use.
