Cost to swap in a 700r4 or a 480le?
Robert82k20
Fitchville ohio
Robert
Sorry I am still a little green with a square body. I picked up a 82 k20 4x4 Lwb that was converted from a diesel to a sbc 350. I’ve noticed my transfer case has a slow leak. I also would like to have overdrive as well. I love driving this truck just would like it to be a little more driver friendly. So I am looking to see what it would roughly cost me to swap in a 4 speed trans a transfer case. Any help would be appreciated.
SquareRoot
Alot!
yevgenievich
Viktor
sad
very sad
less sad
All depends on sourced parts. Anywhere from $1k to $5k
4WDKC
Southern Florida
Kacy
Used 4l80s start around $600, You will need to a TCM or have it converted to full manual valve body..if possible. Shorten rear drive shaft, lengthen front shaft. Possible adpater, possible new tcase if you have a th350/700r4.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
If your plans are to keep the small block, and to keep the engine fairly mild, a 700 properly built shouldn’t be terribly expensive. The 4L80E is expensive to build, converters are expensive, the computer to run it is expensive, the list goes on. The 700 would be e bolt in easy swap, especially if you can find a complete donor vehicle.
4WDKC
Southern Florida
Kacy
you dont need to build them, stock they are rated to 450 tq.
RoryH19
Rory
R10 Silverado SWB
The costs for the 4l80e far exceed the benefit if using for a mild sbc.
The 700r4 doesn't need a computer and just needs the linage to the carb.
The 4l80e will need a standalone pcm to shift unless you are swapping the engine too and will use that one.
Also you are comparing apples and oranges. A 700r4 and 4l60/65e have he same footprint.
The 4l80e is a heavy duty, larger computer controlled trans.
If you have a TH350 trans now, the 700r4 will mate to the transfer case and you will be able to use the same driveshafts.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I agree, the 4L80 is way overkill for a sb.
Robert82k20
Fitchville ohio
Robert
Thanks for the help guys. I will probably look at both. I understand the 700r4 will probably due but I do like to have the assurance of the 4l80. Come spring I will explore both avenues. Thanks again.
RoryH19
Rory
R10 Silverado SWB
Also look into having a 700r4 built up to be strong than stock.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
It depends on your motor but unless you are building a 450+ horsepower motor a stock 700R4 rebuild with a good performance clutch pack and proper shift kit will work fine behind your small block. The key is to ensure that it is adjusted properly by a competent tech, that you add an auxiliary cooler, and also that your axle ratios make sense with the tire size you are using...
RoryH19
Rory
R10 Silverado SWB
Right, I really think a 700r4 will be enough for a mild SBC.
Trans cooler and axle ratio will definitely play a large role.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
The axle ratio is important because the 700 doesn't like to be 'lugged'. It is my understanding they overheat much quicker working at low rpms.
A torque monster big block twisting big tires will leave a 700 dead on the road.
Also the 700 is one of the more expensive builds, especially when beefing it up.
A tranny temp gauge is nice but in the real world it is a little useless, because when it shows your oil is starting to boil the damage is more or less already done. Keeping an eye on the gauge will help you learn what NOT to do and the trick is to NOT repeat it.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
The biggest advantage is the 700 can use stock driveshafts, a 4L80 usually won't be able to.
Controller is fairly simple IMO.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Can you please explain? What is simple, spending minimum $500 ..? I understand a diesel engine controller can me modded to work... but that kinda
stuff is over my little head.
Dale Downes
