coolant bypass hose
RockyGryphon
Wyoming
Jonathan
6.2L Diesel
I'm assuming the smaller hose in the top front of the engine that looks like it goes into the water pump is the bypass hose. Wouldn't it be easiest to put an espar coolant heater inline with this? The top to the espar, and the espar to the bottom / water pump? Wouldn't this put heated coolant directly into the engine block, take it directly out, and not cause a problem when the thermostat opens? I'm assuming that some heat will go to the heater core as well.
kevbak88
