converting a 79 K5 4wd to 2wd
hotrodcases
Olympia WA
Sean
383 stroker
Has any one out there done this? The 79 K5 already has a 2wd trany in it and I was wondering if I could pull the front axle and springs and get a 2wd set up from a compatable doner with an A arm set up. I am looking to do a 4/6 drop. Any help would be great. Looked around and did a search but did not find any thing.
It's been done, make sure to take lots of measurements and be prepared for lots of hole drilling and rivet busting.
hotrodcases
Olympia WA
Sean
383 stroker
Shoot I was hopeing that it would be a direct swap. Is there a wright up on it any where?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i might be doing the same thing soon
i do know the rear spring hangars are different between 2 and 4 wheel drive so the 2 wheel drive ones will need to be used
Green K10
