Connecting with a laptop with Tuner Pro RT and DIY cable.
4WDKC
Southern Florida
Kacy
Double check that it is accessing the .adx and .xdf files correctly. Are the files saved on your C: drive and not on a memory stick?
They are stored on the C: and the program is pointed at them along with the .bin
Georgeb
Wisconsin
George
K10 Burb Z71
This is at the end of my experience. I don' know what to look for now.
yevgenievich
Viktor
sad
very sad
less sad
If it connects but no data stream usually wrong files. Verify the ecm number and download all available files to try(diffetent masks)
4WDKC
Southern Florida
Kacy
I checked the ecm number before downloading and took a pic with my cell so 'i didnt have to take it out again.
yevgenievich
Viktor
sad
very sad
less sad
Which ecm do you have, and have you tried all of the files available for it?
4WDKC
Southern Florida
Kacy
7-7747 is all that is on it. I think it's a Reman ecm
Sent from my SAMSUNG-SM-N900A using Tapatalk
4WDKC
Southern Florida
Kacy
I never get any errors or DA:connected just DA:connecting
4WDKC
Southern Florida
Kacy
Not sure how i missed this post but, it never connects.
yevgenievich
Viktor
sad
very sad
less sad
I would try another computer as well. I have one laptop with extra stubborn version of windows that i need to nuke because it fails to to communicate through serial. But it would fail the cable test when in the programm. Make sure to try different versions of the files as well as a different system. Which chip are yoi using in the cable?
4WDKC
Southern Florida
Kacy
It passes the cable test without being connected to the vehicle but never connects. I also tried it on the same machine running virtual box and windows XP that I have to use for tuning my commander 950 ecm.
yevgenievich
Viktor
sad
very sad
less sad
one thing that i have not seen is specific adx and xdf files that you are using
4WDKC
Southern Florida
Kacy
ADX
42
A03
$42-1227747-v3t
$42-1227747-v5.2
S_AUJP v5 2030_d-nb02
S-AUJP v5 2030_D-u5u6 chip read
S_aujp v5 2030_D-wbo2 innovate lc-1
XDF
$42_1227747-V4T
$42_1227747-V5.9.3
S_AUJP v5 2030_D
none have worked.
yevgenievich
Viktor
sad
very sad
less sad
Have you tried with winaldl and see if it shows connection? I think you would have to try on a different vehicle if other software fails. There is another data loging software that i use for testing only due to being a trial, but the name escaped from me. I will check on the logging laptop this weekend.
johnalen76
