Clutch size
donsanders97
Sealy, TX
Don
350 CID
Needing to replace the clutch on my truck. Have looked up parts on line and there is an option for 11” and 12” for 3/4 ton trucks. Any tips on determining what size clutch I need to replace short of pulling the transmission and measuring.
SquareRoot
Any good 11 inch will be good. I use McCloud and the 11 inch is more than enough in my 85 K20.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Id go 12" personally. When i changed engines in my 86 half ton, from a 305 to a 350, i upgraded to a 12". No issues at all, swapped right over, trans didnt care, but its got alot more grip now.
For a 3/4 id definatly go 12.
Im assuming SM465?
Juggernaut
Illinois
Greg
It really depends more on what you use the truck for. If you're just driving around, maybe pulling the occasional load, an 11" would be fine. If you're hauling a camper, up and down hills, or constantly loaded you will want the greater surface area of the 12". You shouldn't see any difference in pedal feel, at least from diaphragm style and either one will fit. I have always used 12" clutches from Luk or Sachs, both are relatively inexpensive and can take a lot of abuse.
donsanders97
Sealy, TX
Don
350 CID
Thank you for the help. Just didn’t want to make a mistake that I didn’t realize until I had the tranny out
pduffyd
Melbourne, Australia
If you go to the 12" check you have the correct bellhouse to accomodate the bigger clutch.
See the 4 to 8 o'clock position has the big step for the bigger clutch. These come in hydraulic or mechanical setup.
clintC
Louisville, Ky
Clint
C3500
my replacement inspection cover is too small, I would now guess that this is why....any chance you have a part # or know of where a reasonably priced replacement (no original) can be found...thanx in advance
pduffyd
Yeah I had the same problem, I bought an aftermarket one and trimmed and redrilled the holes in the plate for it to fit. Not what I wanted to do, but I couldnt find the part number either!
I think it was this Pn 6263757 ? for bellhousings, 460486 and 6262756 bell housings.
Here is a fleebay listing as an example;
JOD26
