Cab Lights Wiring - Help!
OneShot
Indiana
Hey,
I'm installing cab lights on my '79 C20 and I've hit a snag. The first thing I am trying to do is run the ground and hot wires up the drivers side A-pillar, but when I get my fish tape in the top and down to the bottom I can't see where it comes out. Does it let out into the cab? Into the engine compartment?
I am fishing it through the small hole on the OUTSIDE of the door seal instead of through the drivers side sun visor mounting hole because its more of a straight shot down the pillar. Once I get the wires up to there fishing them over to the visor hole shouldn't be that much of a problem.
If anybody knows where the pillar lets out please let me know! The truck is in pieces until I find out and it's my DD so I'd like to know. Also if anybody has a better way of doing this or tips that would be appreciated. :cheers:
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
It lets out into the cab, but I can't remember if it's up near the dash or down behind the kick panel. I went out and looked for the lead I ran years ago but apparently I did such a good job of hiding it I can't find it now.
OneShot
Indiana
Awesome, that narrows it down. I decided to try and run the fish tape through the passenger side just to see what's going on (I'm assuming the holes are the same on the driver's side). I found a circular hole cut out just above the kick panel vent that I'm thinking might be it, but I can't get my bore scope camera up in there and I don't see the end of the tape. Still searching for the exit hole.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I know I had the dash cap and pillar trim out when I ran the wire, that's probably why I can't locate it now.
chengny
A couple of images showing the factory wire routing:
OneShot
Indiana
Sweet, that's super helpful. So it doesn't come out near the floor it's up under the dash. Looks like I'm gonna be removing the dashboard now. Thanks! I'll post back about what happens in case someone else has this problem in the future.
Sent from my SAMSUNG-SM-G870A using Tapatalk
chengny
I don't think it's necessary to remove the dash (or even the cluster). You should be able to reach up under the dash - above the ground bus block - and have access to the opening:
MadOgre
NA
NA
NA
NA
NA
You must want to sell that red cab by now huh? Ill buy it! :laughing1:
chengny
I haven't been by the shop to check on the progress lately, but it's probably black by now.
This is the end result I'm shooting for (except for the addition of cab marker lights and an increase to 1 ton GVWR:
The fender badges (Sierra Classic 3500) are proving hard to find. I have a set of nice Sierra 3500's - and given the going rate for the SC 3500's (close to $1000) I might just have to settle for those.
OneShot
Indiana
Oh okay, I just have so much stuff wired up under there I must not have seen it. Or I was just looking too far forward towards the firewall. I have a CB and a couple of HAM band radios wired up and running to antennas on the tool box and that's where I have all my coax run (up the side of the dash between it and the door seal) because I can't find a better way to get it up to the top of the dash. If anybody knows of a secret hole for that too I'd be open to suggestions :waytogo:
farmer jon
Nebraska
Jon
k20 Bonanza
I want to do this also. I have a ton of other work to do first.
MadOgre
NA
NA
NA
NA
NA
Very nice! I like it!
I had the same thing in mind except now Im thinking of doing a dark silver/grey with an all blue engine with the shiny intake, carb and air cleaner with black inner fenders, rad support and engine accessories ???
I think a blue engine would look sharp with a grey body
I was originally thinking of this
http://67-72chevytrucks.com/vboard/showthread.php?t=545636
OneShot
Indiana
Sorry for the delay!
Hey folks,
I had to finish some other projects first (Central IN has been getting POUNDED with rain), but I got the lights on!
Big thanks to chengny for the photos. I ended up removing the dash panel and working through a rectangular hole in the sheet metal to the left of the headlight switch. Those really helped, hopefully other people who want to install cab lights will find that helpful.
Somewhere on another forum, they talked about wiring the lights. There is a contact on the headlight switch specifically for the cab lights. Its to the left all the way at the top if you are looking at the contacts on the switch with the knob on the left hand side.
Anyway enough talking, here are some pictures.
OneShot
Indiana
The next thing to do is install the exhaust system that's on the way from LMC Truck. True 2.25" duals straight out the back. Turbo mufflers, no cats. But I'll start a new thread when they come in and I get them on :party36:
builder100
