- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
Oh well thanks keith. Either way it is definitely pretty wizzard. Is there any room on the OPs inside frame rail for a slightly slimmer or custom gas tannk? The frame is wider and taller than a 3/4 ton or half ton, right? If so, I would get a aux gas tank, usually plastic, meant for high mileage peepoples, install the one fuel filler slightly higher, and then plumb to a aux tank on the inside of the frame rail on that side of truck. If you wanted to keep it like it kinda is.
this ford(The left one not the yellow) has a system like this
with a small guard in the bed to cover the part that pokes through like squares have already, and ford never mounted saddles but if they could fit a tank on the inside(it was triangular, with the open area facing the driveshaft) you could do something that would fill a lot more behaved like. Just an idea. I only know about this because I went down a rabbit hole after I learned my ford trailer had the factory aux tank as a truck and my really weird filler neck is just like that one and thought that was cool.
