c20 w/6.2
4WDKC
Southern Florida
Kacy
Im supposed to go look at one tonight, i was told it was running but sat for atleast a year and needs front shaft fixed what ever that means...What should I check for on this engine aside from the usual rust spots?
Front shaft? Did the balancer break the crank snout?
4WDKC
Southern Florida
Kacy
Don't know I havent been over to look at it and pretty sure the person that posted it has no idea what they are talking about.
82Diesel
USA
6.2L
What year is it? I'm most Knowledgeable on 82-83 6.2s, Also being the Rarest years.
4WDKC
Southern Florida
Kacy
85, silverado package I believe, PW/PL/AC etc.
82Diesel
USA
6.2L
Nice!! Okay well... I don't know much about those newer year ones other than they used that ****** Fuel Filter Box Which ALWAYS Leaks, Starter Bolts were more prone to snapping, Good thing it's a 3/4 Ton Only 1/2 Ton had Emissions.
I can't think of any other problems, What Transmission? If it's 700r4 make sure the TV Cable is Adjusted Properly otherwise it's Life or Death for them as when they first came out 6.2s would blow transmissions so fast before it made it to 30K miles.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
So much to look for and so little to see. Most of the catastrophic failure points are not going to be visible, but look for the usual things like gloppy oil, signs of moisture etc. Expect the oil to be black. Pull the air cleaner and see what the intake looks like. If it's a C engine it's probably going to have a lot of soot from the EGR. If you can start it look for blowby from the crankcase breather ports in the intake. One way to get a feel for condition is to see how it starts cold. It may smoke a little but shouldn't be heavy and should clear up in a few seconds.
On a test drive also look for smoke. It probably has dual exhausts so you can see if there's a problem with either bank. A little black or brown on hard acceleration and at high RPM is normal, but you shouldn't be laying down a smoke screen.
If you really want to get fancy you can check the timing advance on the injection pump by revving it up to about 1300-1500 and depress the bottom of the rocker lever on the side of the injection pump. You should hear the engine change pitch and RPM. If not the timing advance is shot. You'll probably need a screwdriver to push the lever. Use some finesse, I've seen some enthusiastic people break the levers. If it's got more than about 150K I wouldn't be surprised if it's shot. It's not the end of the world, but it will probably need a rebuilt pump.
82Diesel
USA
6.2L
Blue Ox, Detailed it as I would of but my Lack of Thinking process denied me to. Congrats :D
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Oh, there's more, but I can only spend just so much time typing. So I hit the highlights. :rolleyes:
4WDKC
Southern Florida
Kacy
3/4 ton with 700r4? sounds like it was designed to fail.. Someone else bought it.
82Diesel
USA
6.2L
Ya... Surprisingly mines stood up. 152k miles on it.
sszcam
