Bought a truck.....
lothar863
Nashville TN
Colton
r3500
7.4 FI
I was getting tired of getting told that my 94 c1500 wasnt heavy enough to tow things so I was browsing for 1 ton trucks and I cam across a 1989 r3500 crew cab on craigslist
Massive coolant leak but ran and drove
Went out and looked at it heard it run for a short time and struck a deal.
$2,295
it shows 3,2xx on the clock and from looking at it i think it has only rolled over once for 103,2xx miles
had it towed home and BARELY got it into my shop
I have been working on getting it into running order.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
lothar863
Nashville TN
Colton
r3500
7.4 FI
Just a quick post before I left work.
So the truck was parked under I am guessing a truck for a long time. and the crap isnt coming completely off with pressure washing. It has been resprayed at some point.
It also has what I think is the wrong style tailgate on it.
There is a decent bit of....iffy? wiring
lothar863
Nashville TN
Colton
r3500
7.4 FI
The interior is weathers but not terrible
lothar863
Nashville TN
Colton
r3500
7.4 FI
And the exterior doesn't clean up too bad.
lothar863
Nashville TN
Colton
r3500
7.4 FI
the bottom of the truck isnt too bad.
I dropped the transmission and found the missing freeze plug and there was another on the front drivers side of the engine. Since I was there I dropped the oil pan and cleaned it up
lothar863
Nashville TN
Colton
r3500
7.4 FI
The flex plate did a number on the freeze plug
lothar863
Nashville TN
Colton
r3500
7.4 FI
Same thing since I was there new oil pan gasket and a new rear main seal
I did see some cold start damage on the bearing but it didnt look too bad
lothar863
Nashville TN
Colton
r3500
7.4 FI
I replaced the fuel filter and then moved to the top of the truck.
I replaced all of the battery wires.
New battery
Reconencted all of the AIR pump stuff
new air filter (it didnt have one before)
lothar863
Nashville TN
Colton
r3500
7.4 FI
From the pic above the original puke tank was there but the barb was broken off and there was just a random tank knocking around in the engine bay. I went to lowes and got a threaded to barb fitting and taped out the hole where the plastic barb was and threaded in the fitting. then i roughed up the plastic around the hole and epoxied around the fitting.
lothar863
Nashville TN
Colton
r3500
7.4 FI
I filled the cooling system (making sure there is antifreeze)
Filled the engine with 5 qts Valvoline 10w-30 and 1 qt marvel mystery oil
I put the flex plate on to balance the engine and fired it up
I ran it through 4 heat cycles and no leaks
Cryptik
