biggest tire that will fit?
bbc
Ark
Cory
gota 83 stespside im wanting to know if anyone knows the widest tire i can fit in the back without cutting uo the frame?? for slicks
WIDE. Is your truck lowered? I think the lower you go, the less clearance you'll have.
Bagged Dually
Joplin,Mo.
Kris
CUMMINS 12 valve
Yep that's correct. The lower you stand the narrower of a tire you'll have to run. Get your truck off the ground, pull a wheel and start measuring. That's about the best way to go about figuring it out. What fits 1 truck might not fit another truck due to the suspension, wheel offset, the difference in deflection on different 4 link setups. Someone might be able to give you a ball park number ,but if you really want to squeeze every little bit of room out of your fender and frame clearance just figure out exactly what your truck has and stuff it full of rubber lol.
ohchiiit
huntsville al
brian
468ci
mine has a flip kit and on the stock rally rim i have a 28x10.5 on it and it tucks and hides good!
Green K10
