Big Block Valve Covers
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Hi. Im looking for 454 valve covers. Maybe black? No markings on them.
Tall enough to clear 1.7 rockers
Show me what you got , maybe even tell me what youre looking for in exchange.
Vbb199
Salisbury NC
Vince
Oh. I forgot.
Perimeter bolt style.
nvrenuf
Mobile, Al.
Just fyi, stock stamped style rocker arms are 1.7 so short valve covers will fit. If you are running aftermarket rockers with polylock type nuts then you'll need tall style covers.
QBuff02
Central IL
Quincy
I have a set of these plain tall aluminum ones sitting under a bench at home because I replaced them with a tall set of fabricated ones.
Vbb199
Salisbury NC
Vince
What would ya be needing for those ?
I want to debadge my motor so i xan advertise it as a 400 bbc
I get tired of having to discuss the price of the motor i have plus its displacement with people when i open the hood.
If you want to confuse someone get some custom "Olds 260ci" or similar for the valve covers, itll make for fresh conversation
QBuff02
Central IL
Quincy
Ummm.. hows $40 plus the ride sound? If you're good with that, I'll have my wife figure out what shipping will be.
Dooley
North Coast
RW
V30
When I had my 64 Ford Fairlane GT it had 289 Hi perf emblems on the fenders.
That's what I said it was while it was actually powered by a 427 Chevy.
When they looked inderneath and questioned the even spaced header down pipes and rear sump oil pan I simply told them it was a 302 setup out of a Bronco. Also had Muncie Rock crusher trans and Ford 9" rearend.
The hood ws pinned on all 4 corners, had a custom straight axle, and custom inner fender panels.
Fooled most of them!
Short polylocks will clear stock height valve covers. I have a post somewhere about that, because the L29's can't use a taller valve cover due to the throttle body going low over the top of the passenger side valve cover. If you go with a bigger cam circle, you have to go to adjustable valve train and most people go to a roller rocker of some kind at the same time. Standard polylocks will hit, but there are a few short polylock versions out there that will clear just fine.
It helps that a lot of ford engines get dressed in gm HEI distributors these days. Almost like a 1 wire self contained unit was better than Durash** 2 :) So you maybe just could pull it off yet again or with a something crazier yet even lol
You need to find some nos TargetMaster 366 decals, lol.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
My friend has some stock style black stamped steel ones off an 89 c30. If your looking for something like that.
Vbb199
Salisbury NC
Vince
Heyo, i let me know whenever its convenient, ill get with ya sometime. Not a big big rush at the moment, but its on the list of things i want to do.
dob555
