Best paint to cover frame and underside of bed?
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
The title says it all mostly; what should I put on my frame and under the bed when I take it off to swap it? I want it to be pretty easy and dummy proof. Doesn't have to look spectacular but it needs to keep the rust away.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I've become convinced that the higher dollar stuff doesn't do a thing the cheap stuff doesn't.
Rustoleum Rusty metal followed by the top coat of your choice is no more or less effective than Chassis Saver and the like in my experience. They all need touchups every few year's.
Por15
donmateo
WI
What condition is the frame in and what kind of prep did you plan on doing? If you wanted to do really easy you could just do a quick sand/wire brush and rust converter.
zbhover
Glasford IL
I'm building a 350 powered VW beetle on a shortened and lowered S10 chassis and I used Master Series Silver (http://www.masterseriesct.com/) with hurculiner roll on bed liner over that, and I plan on using the same process on my 76 K20.
I had everything stripped down so I wired wheeled and sand blasted the frame, but I know lots of people who have just wire brushed off the loose rust and brushed on the master series with good luck. A lot of VW people swear buy this stuff, for a test I painted a rusty piece of bar stock with it and threw it out in the driveway all winter and even getting snowed on a salted it still looked good in the spring.
Wire wheeled:
Sand Blasted:
Painted with Master Series:
Hurcilined:
Re-assembled:
I might just throw this engine in the k20 and build something else for the V8 beetle since that project has been on hold for a while.
I also used the silver on the ford 8.8" rear end:
A couple links for more pics:
http://www.v8beetleresource.com/chassis10.html
http://www.v8beetleresource.com/chassis14.html
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
So do you all think I could get away with taking a wire brush to it, priming it, and then slapping on some bedliner, (probably herculiner, as I have a new gallon of it laying around)? Along with wiring, paint and body work really isn't my thing so lord I apologize for maybe seeming to be uneducated!
Georgeb
Wisconsin
George
K10 Burb Z71
I would say no. You will want to use some rust converter, primer, paint then bed liner personally I would stop at the paint step. Up here in salt country you will want to protect the underside of the truck with some rust inhibitor too. I plan to use a product called fluid film.
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
Alright I looked up the rust converter stuff and that route looks like the best way to do it, at least for my needs.:cheers:
donmateo
WI
I believe Rust-Oleum makes a rust-inhibiting primer. Do not put bedliner directly over rust, it will make it worse. Pre-treating is a vital step or your frame will rot out in a few years.
carlgm
Fl
Karl
'85
Eastwood has rust converter. This stuff works as advertised.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I painted an '86 K10 frame with Rustoleum Rubberized Undercoating seven years ago, and it still looks good today. I don't know how people feel about that particular product, but I did my wheel wells in that, and I planned to do the frame and bottom of the body in that manner as well.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Heavy Rust or something, i have a gallon of it in my garage, works equally as well as Chassis Saver, which I also have a gallon of lol.
88SQDRW
