85K304SPD
- Mar 29, 2022
- Las Cruces, NM
- Richard
- K30
Spray can of white lithium grease, liquid wrench brand, I believe.
it also works well for a undercoat protection for the awful beet juice that Ohio coats the roads with!!I've never had good luck with white lithium grease either.
I finally discovered Fluid Film several years ago. It makes a fantastic lube that lasts a while and I'm still discovering excellent uses for it. I've found out that it penetrates very well too, even the super tight clearance joints of pliers.
I think white lithium grease comes in different qualities, I have had stuff that gets hard and chalky in less than a month and stuff that lasts.I've never had good luck with white lithium grease either.
I could believe that. That has been my trouble. For example when I have sprayed down the door hinges on my Dodge and tend to make a mess with the stuff in general, and a short time making noise. Then the over spray starts collect dirt and crack. With silicone, at least the WD-40 silicone it lasts much longer. Could well be the brand of lithium, I wonder if you could recommend a brand, I might order some for the guys to try at the shop.I think white lithium grease comes in different qualities, I have had stuff that gets hard and chalky in less than a month and stuff that lasts.
good stuff, guns, auto, etcThanks for that suggestion too.
I have to confess I've never heard of Fluid Film before now. But I have heard of lanolin-based products for firearms.
