best bolt on performance mods
Nick.koehler6
IL
Nick
350 5.7L
Best bolt on performance mods..going to a car expo and have some cash..chevy 350. Has edlebrock 600cfm carburator. 1406. I have dual flowmaster 40's.
Depends on what you currently have going on. Is the motor stock?
rich weyand
Bloomington Indiana
Rich
Best performance mod is probably a broadband A/FR meter so you can tune the carb properly.
firebane
Calgary, AB
Curtis
I agree with Rich and the wideband.
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Which A/FR meter would yall recommend?
Sent from behind you.
rich weyand
Bloomington Indiana
Rich
olemans85
South Jersey
Aden
358 roller
Hi Rich,
This will work with a Qjet carb?
From a '85 305, reusing on a 350.
rich weyand
Bloomington Indiana
Rich
Any carb. All carbs have the same goal, to create the optimal air/fuel mixture. They don't do it as precisely as fuel injection, because fuel injection has a computer monitoring an O2 sensor in real time -- it is a closed-loop control system -- where a carb is adjusted and then runs open-loop. But you will never get a carb to its best settings without a meter so you can dial in the carb settings to get the mixture right.
An A/FR meter hould be the next thing you buy after a timing light. THEN worry about headers and manifolds and carbs and and advance curves and exhaust systems and all the rest.
350runner
tx
Ceasar
super charger....
350runner
tx
Ceasar
:gathering:
Jacknife
Va.
James
K-25
Hi Rich. I assume that you have to weld a bung in the exhaust system for the sensor? A sensor kinda simular to a o2 sensor is what give you your readings ,Right?
Thanks for your advise.
Green79Scottsdale
G.R. - MI
Bob
Yes.
Obullard74
