Bench Seat Not Moving.
GunMan9
Yorktown
Brandon
I reupholstered my seat and now I feel as if the seat is not moving all the way back. Anyone got any ideas why this maybe???:beatdeadhorse5:
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
anything fall behind it when you put it back in? I've changed seats before and put them in with more cuishion than old on and they sit funny especially in a truck I've drove for years
J Knight
Baytown TX
82 Chevy
350ci
Check to make sure the wire to release the rightside track is tight enough.
This may sound sarcastic but it's not meant to be.
Do you think maybe the frame is all the way back but the new padding is making you feel like you're closer to the dash and higher up?
Never mind - just saw that towjoe already covered this...
If you still feel that the bench is not sliding fully back, you can check that it is hitting the front and back stops by measuring how much it moves.
Seems like much more, but actually the full range of adjustment on those bench seats is only 4".
It can be easily measured at the bottom of the seat. Use the position of the seat belt retractor casing in relation to the hump above the sill plate.
GunMan9
Yorktown
Brandon
Didnt add new foam. The seat was in perfect condition. Just feels like it is 1" short.
joshuars
