Bellhousing Top Bolts
Kilian
Wisconsin
K
C2500 on its way to a K2500
Searched the site and couldn't find a recent thread, so sorry if this is a frequently asked question.
I'm removing a 350 engine from an 87 Chevy V10 with 4-speed. I'm hoping to separate the bellhousing from the back of the engine and leave bellhousing, transmission, etc. in the truck. What's the best way to remove the top two bellhousing bolts? I can feel them on either side near the top. Just wondering if there are any tricks to getting at them. There's no removable transmission hump which would really help. Would removing the distributor make it easier? Thanks for the help.
Dutch Rutter
Independence, Or
Joshua
Best way I've found is by pulling the dizzy and carb then using a wrench (ratcheting type preferred) from the top.
Edit: should have mentioned only use the ratcheting type after breaking them loose. :crazy:
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
It’s possible to do it without removing anything. I did it a week or so ago and I’ll be doing it again tomorrow...yey
Use a second wrench as an extender for your 9/16 for more leverage at first.
I used to R&R alot of transmissions for rebuilding back in the day. Best investment I made was a 24 in 3/8 extension and a wobble adapter. Not a univeral joint, but a wobble adapter. Shoot that over the top of the transmission from underneath after you've pulled the crossmember and let it droop about 2 inches and they're in plain site and easy to access.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I've always done the same thing as hotrod. If you don't have a long extension just get a few shorter ones, definitely need the swivel adapter though.
Yes, the swivel is a better name. I got stuck on wobble when bucket said it. Now I do have some extensions that will allow wobble and those work too on many vehicles then you don't even need the swivel adapter.
PrairieDrifter
North Dakota
Mason
Oh yeah I've used those a few times, they're nice for smaller extensions as well!
My friends and I have always called those wobbly sockets, wobble sockets since they don't necessarily swivel, and they aren't adapters they're just.. well wobble sockets lol. They're pretty handy as well, just less angle available with those.
Wobble sockets, swivel sockets, whatever you want to call them. The type with the ball joint in them are much easier to control than the universal joint type. It's another case where you get what you pay for.
Kilian
Wisconsin
K
Thanks for the suggestions. I don't have any of the wobble sockets, but made do with a universal joint, extensions, and breaker bar and got them out. Engine came out today.
mikejeden
