Bed looks like it sits cockeyed.
davehoot
Dave
When looking at the truck from the rear, the right side always looks low.
I have changed out all the springs both front and rear. Anyone ever
found out what causes the square box truck to sit this way?
87ChevyR10
Kansas
NA
NA
NA
Do you always put gas in on that side? If so, the extra weight could cause it to sag a bit on that side. Just a thought.
davehoot
Dave
No, good thought though.
Konas new ride
Alberta
Gerald
how big is your girl friend? :hump::Whoa:
DavieL
Alabama
Davie
5.3 LS with Holley EFI
Mine is the same way, the right side is just a little bit lower. I've changed everything but the leaf springs and the body mounts.
Is it the bed or the whole truck?
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
my drivers side sits almost 3" lower than the pass. side
marks86
Latham, NY
Mark
12v Cummins
Replace with poly body mounts
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
mines from being rearended
alysco
