BBC 454 dipstick length?
QBuff02
Central IL
Quincy
I just want you to know....
That I just liked this comment and it was your 9,000th like.
You are welcome!
He's a solid dude, so I gave him an extra like just because. And also just because the now imperfect number might drive some people's OCD off the charts!
:emotions33:
ajd89
Central Michigan
andrew
First one is from a 89 mark 4. Second is from the 91 mark 5 engine I just got in it. The tubes were the same size so i used the better of the 2 but the dipsticks are just a little diffrent length. Would have thought they would be the same.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
You are welcome!
Wow, didn't even think about that. Lol
78C10BigTen
pennsylvannia
C10 BIG TEN
I can't believe my eyes.....a Fram oil filter?? I cannot unsee that which I have seen!!! LOL I'll just chalk it up to the glare off those tires! Lookin' good!!!:cheers:
All i use is fram!! Whats wrong there???
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
I use to use Fram too until I seen a number of side by side comparisons with other well known filters. The Fram filters seem to have much inferior components and even are assembled haphazardly.To each there own but I personally will not use another Fram product on any of my vehicles. I now only use WIX products, a few pennies more but I feel it's worth it to help protect my rides better. And I also put rare earth magnets on the bottom of the filter when I change them. The video is easily found on Youtube. Just type in Fram oil filter and it should be close to the top of your results
idahovette
Weiser Idaho
Perry
K20-K10
Shorter but stiffer. Not like the long flimsy stock stick. Like try'n to push rope. Lol
THAT brought back old memories. They used to call my brother "ROPE" when he was in High School!!
82sbshortbed
Fuckemall!!
SE Texas
Doug
Here's a pic of the oil pan. I like how the drain plug is in the middle pointing down on the bottom of the pan.
I added another quart today and it came up to the add 1 quart spot. That's 8 quarts now.
Big Chip
Michigan
Kevin
C35
I’ll try to measure my dipstick and tube tomorrow. It’s stock and I’m pretty sure it’s a 7 quart system with the filter.
builder100
