Ball Joints Need Adjustment?
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
After installing ball joints on the 1/2 ton 4WD for the first time, they appear to be too tight after torquing them to the specifications of 70ft-lbs lower, 100ft-lbs upper.
The adjustment sleeve was inserted to the recommended location “exposing 2 threads”, but was still easy to turn without any torque really. 70ft-lbs was what was specified for that sleeve, but I never got there with two threads exposed.
When testing the resistance of the knuckles to turn left or right, the scale read 30lbs on the drivers, 60lbs on the passenger side. According to the Haynes manual, they should be 20-25lbs as shown in the picture below.
Do I need to loosen the ball joint nuts and unseat the knuckle, then tighten the adjustment sleeve for the upper ball joint?
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Just loosen the ball joint nuts and see if it frees up? Seems like it would need the sleeve adjusted.
scrap--metal
MN
Calvin
'85, '81
K10, K20
It's been awhile, but there is a procedure to torquing the ball joints. If I remember correctly, the lower ball joint is torqued first but not all the way. Then the upper ball joint is torqued to spec. Lastly the lower ball joint is torqued to its final spec.
Regarding the sleeve, I would follow the torque spec over any recommended visual cues.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Thanks @scrap--metal I figure that I need to remove the ball joint nuts, readjust the sleeve and start over installing them again. Before I do, I thought I would see what experiences others have had. Thanks for your input.
scrap--metal
MN
Calvin
'85, '81
K10, K20
I think you have the right idea. Hopefully others will chime in with their input as well.
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Well, that was easy. wrenched on the adjuster sleeve for the upper ball joint half a turn (pushing it downward), and then torqued the lower to half of the specified torque setting (35ftlbs), then torqued the upper to the specified torque setting (100ftlbs), then torqued the lower ball joint the rest of the way to the specified torque setting (70ftlbs). 27lbs of resistance! Thanks!
86 Square Body
