axle swap
Ingram
Sanford, N.C.
Bryan
Found a 3/4 ton 8 lug front and rear axles at a salvage yard for $150 a piece. What else if anything would I need to take off the truck for the axle swap?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
1/2 ton and 3/4 ton front axles are the same except the outer hub assemblies have 8 lugs instead of 6. Even the rotors/calipers/pads are the same. 78 and older used 3/8" banjo bolts on the calipers and 79-up used 10mm. Your front d-shaft will be the same but the rear may be different, if yours is short bed, 3/4 tons are long bed. I would get the rear d-shaft too, and expect to have it cut down at a driveline shop to fit yours (also depends on slip-yoke d-shaft or slip-jointed d-shaft). 14-bolt rear axles found on 3/4 ton trucks have different dimensions compared to 1/2 tons (10 and 12 bolts) looking at the centerline of the axle shafts and the length of the pinion to the u-joint yoke. You may want to grab up as much of the park brake cables towards the back of the truck too if they're any good. You'll also need the spring plate that the u-bolts go through to bolt it in. The u-bolts are gonna be about 1/8" or so bigger than your 1/2 ton stuff. If the guy torched them off grab the pieces of one so a spring shop can figure out what size you need. You'll also have to figure in the thickness of your spring pack(s), as well as any lift blocks you may be using.
Even though the calipers and pads are the same, the 3/4 ton rotor is bigger to give better braking power. The only advantage to swapping the entire front axle is if the replacement has the gear ratio you want.
Oh, and you can reuse your stock rear shaft with a conversion u-joint, #447. Running the rear shaft with the larger joint is a better way to go though.
Ingram
Sanford, N.C.
Bryan
Thanks for the info. The axles are still on the truck so everything is available .
hirschdalechevy
norcal
rich
k-30
You will also need the top plates for the u-bolts in the rear , the holes are farther apart.I have also ran the conversion joint's without many problems but the right way to do it is cut the 1/2 ton shaft and have the 3/4 ton end welded on and have the shaft rebalanced
:grd::grd:
hirschdalechevy
norcal
rich
k-30
:grd::grd:
sorry crazy4offroad , I just saw that you told him about the top plates already , (it been a long day)
If you happen to be running lift blocks, then the 1/2 ton spring plates will work. The u-bolts are long enough that it's no problem squeezing them so they fit in the holes.
Snips71
