Mikeyworks
- Dec 21, 2016
- Havre de Grace, Maryland
- Michael
- K10
In my search for tires, I found a pretty good looking deal on a set of tires, wheels, and 3/4 axles.
The axles are off a '70 GMC Jimmy and appear to be 3/4 ton or 1 ton since they're 8 lug.
View media item 7023
The rear axle needs to be rebuilt as the owner/seller shared this picture with me:
View media item 7024
Looking at this it looks like a c-clip let loose. He said he didn't open them up.
From a logistical stand point, how hard would it be to swap out these axles with the ones on my K-10?
I can rebuild that mess, not a problem, but would most of the spring perches, shock mounts, brake lines, pinions, etc. match?
The pinion/u-joint is the biggest one as I have heard through other discussion that the 1/2 ton and 3/4 ton have different pinion connections.
Many thanks in advance!
