- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Yep you're right. I didn't catch the 1 ton frame swap. The D70 perch width should be the same as an 1 ton whether it was a dually or SRW didn't matter. Perch spacing was the same. IIRC, even on the Cab & Chassis 1 ton, spring perch is the same, but the C&C rear end is narrower from Drum to Drum.
Yep, and those brake bleeders are awful close to the spring on those C&C trucks.
