Any upgrade 'hacks' to the stock heater blower fan?
I put in a toggle switch, between the fan motor and the dash switch, so I can turn the fan OFF, when its cold. also keeps it from running all the time. Hi comes on regardless of toggle position. blue wire I think. I also used a clothes hanger rod, on brackets above the shoulder harness. then I hung clear plastic down behind the front seat. Redneck 1/2!! and yes I think AC fans are diff. than non-AC. Rod in AZ
Heater only truck, I put a toggle between this brown wire and it allowed it to turn off. I broke the panel, by actually just trying to slide the thing... wanted to control the speed and I just neeeded it on heat so I actuate the cable with hand fished in lol
you just guess the right one so its not cold
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
Just working on my heater box tonight before I install it and thought I would post some stuff on what I found and my new heater core.
The metal plate to the left I the second picture let alot of air blow past and was quite wrinkly when screw in. So I added some good two way tape and seamed to seal it up good. This is a non ac box so yours may differ.
Obullard74
