Aluminum Radiator Supplier?
GregL
Palm Springs, CA.
Greg
K 20
Time for a new radiator for my 77K20. Who do you all recommend for a direct replacement?
Sublime
usa
m
Went from a standard 2 row to a Champion 3 row aluminum BUT I had to fabricate the top and bottom rubber mounting insulators. I ordered 2 different sets of mounting insulators from LMC and made them work. I cannot remember which insulators I ended up using :(
78C10BigTen
pennsylvannia
C10 BIG TEN
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Get a good rad shop to recore your tanks. Pricey but the best way to go imo.
Some (many..?) rad shops say you can't get copper cores anymore... so go find another rad shop because they are just too lazy and/or don't want to stand behind their work... which they would need to do if they made the rad.
Easy money to change out to new parts I guess...
I realize you're asking about aluminum rads... I just never recommend them. I find they are too vulnerable for trucks... if you happen to drive like me for example.
Schlagger
New Mexico
Will
C30
What's vulnerable about an aluminum radiator? I've never heard anyone recommend against them before.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Im using KKS three row aluminum units from ebay in two of my trucks. Had to do as Sublime said though and get crafty on the rubber mounts. The radiators are good. Run cool and have been trouble free. Also look damn good.
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
I picked up one for my '83 from http://www.speedcooling.com/
RAD-6161-HDDF-TRK 1973 - 1987 Chevy/GMC Truck Aluminum Radiator - 2 rows of 1" tubes, Dual 11" HP Fans, Aluminum Shroud, Automatic Transmission
rpcraft
Robert
LS 6.0 364 CID
If you want a low buck solution you can use a cu730 radiator from spectra and its only about 130 bucks shipped through Amazon, but I am sure you can find it at any chain store. It's an OEM replacement for 99 - current gm trucks, and it'll probably out flow most of your old school 4 core radiators. It's very popular rad for LS swaps in Squarebodies, but I see no reason why it would not work well with a stock motor.
joseph916
