alternator up grade!
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
any one know if there is a difference between alternators on a big block and a small block?? Looking to upgrade my plow truck alternator,1989 chevy 1500, from 105 amp to 140 amp. found one but its for a 454 on a 1990 chevy, anybody got any ideas??
CRM
Pasco, Washington
Casey
K2500
350 CI
Looking on Rockauto both the 350 and 454 take the same one. Should be ok.
SirRobyn0
Rob
Yes this is correct. The short version is a 350 and 454 alternator will interchange no problem. And it wouldn't matter what year (well at least to a point) but anything off a square at least or van or even a car will work, but the pully my need to be swapped, for example using a V-belt driven alternator on a rig with a serpentine belt, you'd need to swap the pulley on the alternator.
Also as a side note, if your truck has a V-belt alternator running a high amp alternator sometimes causes problems with the belt squealing under high demand, for example dead battery, jump truck, the single V-belt just can't turn 140 amps worth of drag on it. And under those conditions it'll burn up the belt pretty quick. Obviously if your 87 has a serp belt that's not a concern.
greyghost
vic
you might have to reclock it depending on where its clocked and if wiring harness will reach
87ScottW
