Air lift helper kit #59501
bluex
Spartanburg SC
C15
Complete used air lift helper air bag kit. This fits Chevy/GMC, ford or dodge. Its all here except for some of the dodge specific hardware to space out the inner fender liner. Asking $150 shipped OBO. This kit retails for about $300 new, its in great working condition...
HRPC EDIT : Corrected Part # in Title. :waytogo:
Phuck me.
Air lift helper kit #51501
I'd probably think about bending over to get my hands on those things lol. :sudu:
bluex
Spartanburg SC
C15
Re: Air lift helper kit #51501
:rofl:
Can these just be filled like air shocks?
Yes each line has a shrader (sp?) valve So you can fill each bag independently to balance the load/level the truck. Air lift also has a compressor system if you wanted on board air.
Lol!
I got an on board electric compressor with 90 lb pressure shut off switch. Dash mounted sided to side inflate controls with dual gauges, Tubing and fittings. Even a self leveling valve off a Peterbuilt tractor waiting for a set of bags like that. They are the missing piece in my puzzle. I'd grab them up if I could. I even got a lanyard valve and set of Peterbuilt horns sittin in the same bin. Some day...
bluex
Spartanburg SC
C15
So why can't you get them? :shrug:
300 a week to the ex for starters. Are they for 4wd or 2wd? I tried to google that part number and nothing comes up.
bluex
Spartanburg SC
C15
Ouch! Here's a link to the kit, I got the part number wrong in the title...
http://shop.airliftcompany.com/product/0/59501/_/RideControl;_Leaf_Spring_Leveling_Kit
I don't think 2/4wd matters it just says you need 6" between the tire and the frame. On 73-87 the upper bracket needs to be flipped from the way I have it pictured above according to the instructions...
I wouldn't be opposed to trading for a nice set of air horns an a valve....
Ooh! Ohh! really?!!!!! :hump:
I'll get them out this weekend and get you some good pics and let me know! :D
Posted From Hell
bluex
Spartanburg SC
C15
Posted From Hell
Ya really, I want a set for my 98...
Here they are, set of Hadley square belled air horns with caps off a Peterbult. These were from one of our trucks that laid over on the highway about 10 years ago. The mounting tabs in the back snapped off so I made new base plates out of aluminum. Other than that these are in very nice condition. The lanyard valve is very old but still works. You can drill out the rivet holding that eyelet to attach a new cable.
screen capture software
bluex
Spartanburg SC
C15
Im not really concerned with looks as long as they work. They will probably wind up mounted under the hood or under/in the bed.
Can those fittings be removed an replaced with ptc style fittings or are those compression fittings reusable?
Yah the nipples will thread out, they are regular NPT threaded compression fittings. They are what is holding those base plates on.
dhaayer
