adding Guide Plates
RustyBuckets
Kansas City
Jake
Do i need to machine heads or get screw in studs for Guide plates? (1979 sbc 350) vortec heads
BigAl285
Wisconsin
Allan
383 S.B.C
What are you all doing to the heads and the motor? Or what are your plans to do?
RustyBuckets
Kansas City
Jake
They are stock 906 vortecs on a carbed motor, the rockers are from the old smog heads that were on the truck. I have just seen all of the guide plates held down by something but I dont have anything securing them except the pushrods.
RustyBuckets
Kansas City
Jake
My rocker studs do not have a hex head. nor any head, they appear to be push in
BigAl285
Wisconsin
Allan
383 S.B.C
I believe all center bolt style valve cover heads use a self aligning rocker arms. If you put in the guide plates then you will have to get new non self aligning rockers.
RustyBuckets
Kansas City
Jake
I cant reuse my old non self aligning rocker arms?
BigAl285
Wisconsin
Allan
383 S.B.C
If you want after you get the guide plates put in you can. If it was me I would call a local machine shop and talk to them, not sure how much it is , or what is involved to get guide plates put in.
RustyBuckets
Kansas City
Jake
I already Torqued the heads down.... -_-
Should i just say screw guide plates and buy some self aligning rockers?
BigAl285
Wisconsin
Allan
383 S.B.C
If you pull the heads off you will need to replace the head gaskets then. I would figure out exactly what you want to do to your motor or what you expect out of it. Rather then paying for something twice or not using it after a few months. If your going to pull them off I would have them checked out. Head work isn't cheap. I knew my heads wont be cheap, I put $1100 into my heads. I had bigger valves / new valves, 3 angle valve job, port / polished, milled.
RustyBuckets
Kansas City
Jake
I bought brand new vortec heads. I thought i had planned it all out, but missed this part i guess.
RustyBuckets
Kansas City
Jake
Does anyone have a suggestion on something i could do without pullin the heads back off?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Buy self aligning rockers, and be done with it. You're making this way harder than it needs to be.
beetlejuice01
