AC Delco Radio
Covington, WA
350; 700R4
So the radio a bought from an '85 works fine...except for changing stations.
I can hit the buttons to change the stations that are saved and it works, I can turn it on and turn it off...but I can't change the station with the knob!
The knob turns but the orange frequency indicator doesn't move. :banghead:
I realize I got what I paid for ($5) but is there any easy way to fix this since the knob turns and the radio works otherwise?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
So it won't change stations even though the knob is turned?
I can't recall exactly how those worked...I fool with the later ETRs...
I have a feeling this problem is taken care of. :grd:
Covington, WA
350; 700R4
Well, I'm going to call around for a radio/electronics repair shop to see what it would run to have them fix it. I couldn't find anything inherently wrong with it when I took the cover off. The knob turns a screw inside the radio, but after that I'm lost because I don't want to mess with the circuit boards. Couldn't get a little nut to come off a board and didn't want to break it even more.
Oh, so you are still getting this fixed then. You acquired another one though right? Maybe I misunderstood you post in the other thread.
Covington, WA
350; 700R4
Yes, still needs to be fixed. I bought it yesterday for $5 off the '85 I pulled the AC from. Hoping it's a cheap fix. I'd really like to use it.
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
it should have a flat head screw adjustment on the side it help a disk bite better on the tuner its a geared set up for the tuner
timm
Missouri
tim
I am having the same issue. Were you ever able to fix it? if so, how? I have a very low milage truck with a mint original radio, and would like to fix it.
duckboy_17
