Ac Delco ignition module not compatable wIth duralast distributor?
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
I'd say that's unlikely the timing chain jumped. did you pull the distributor before? I can't remember. if you did, you needed to restick it just how you found it when you pulled it or you needed to find top dead center on No 1 and stick it with the rotor pointed at No 1.
Thank you. I had my distributor timed about a year or 2 ago so I know it hasn’t changed it’s “clocking”
Hugomartin
Banned
Nc
Hugo
Tdc on comp stroke is right when it starts to blow out air on cylinder 1 I take it?.
Hugomartin
Banned
Nc
Hugo
Hugomartin
Banned
Nc
Hugo
The rotor is pointing right between the #1 and #2 ,should I move my plugs?
Hugomartin
Banned
Nc
Hugo
It’s too far retarded if rotor is between #1 and #2 right?
Hugomartin
Banned
Nc
Hugo
I tried to start with rotor between #1 and #8 .... still no start seemed too advanced and actually had a burnt plastic smell hmm
Hugomartin
Banned
Nc
Hugo
I tried twisting the distributor all sorts of ways still no start. Had the rotor lined up with number one still no start. Tried advancing and retarding still no start
gmbellew
Kansas city
glen
suburban 1500
if you are sure plug wires are on the cap right and the distributor is stabbed correctly for timing, there is a "crank no start" chart in the drivability manual. follow where that leads you. anything else is a shot in the dark.
Hugomartin
Banned
Nc
Hugo
Is the 'drivability manual' in the library on this forum , i see the 1973 to 1991 service manual in the library is that it? If so what page ? Im trying to browse through but i dont see the chart
gmbellew
Kansas city
glen
suburban 1500
the emissions and drivability manual is what you want.
Hugomartin
Banned
Nc
Hugo
Ok I found it , I thought this would be easy lol but here is the first chart I came across thanks
Hugomartin
Banned
Nc
Hugo
Could it be possibly a bad throttle position sensor that keeps it from starting?
gmbellew
Kansas city
glen
suburban 1500
make sure you have the right chart for your engine.
also, I'd be sure to trace all the plug wires to make sure that they are all in the correct spot and order on the cap.
black_85c10
